1 - 2 of 2 Posts
So another AC problem, I did have a read and a search but can't seem to find a solution that works for me.
So I have an Air Con system that works absolutely fine for about 5-10 minutes before it cuts out on me. Pretty usual senario in which I replaced the relay with a second hand one and still had the problem so I thought maybe that relay wasn't good so ordered a brand new genuine honda replacement which cost me a bit more hoping it would work but still no good.
I have also previously had the system regassed in January with no leaks found but as I haven't used the AC properly til now was unaware of the problem.
When I try to re-engage the AC it usually doesn't work but sometimes it does for another 5-10mins before cutting out again no loud noises or anything apart from a change in the smell of the air coming from the vents.
Hope someone can help me out here or would it be best to take it to a garage?
1 - 2 of 2 Posts
