I have just got myself a racelogic performance meter and I'm getting ready to go and do some runs in a oem fn2 and some in a sc fd2.
Was just wanting to know the oem times of a fd2 so I can compare.
Auto car states 0-60 in 6.5 and 0-100 in 15.98.
And then I googled it and saw
0-60 6s and 0-100 15,2
So I'm a bit confused I know the times will vary as temp wind launch tyres psi etc! But wanted to know what you have had run either at santapod or timing equipment.
Thanks jady
Autocar will have gained their numbers the same way you are about to, stick some off the shelf meters in the car, then a member of staff belts it up an airfield.
The FD2 SC means supercharger correct?
Don't know but....on the 0-60 to be worst than stock:
- low traction on launch due to higher torque, makes difficult to put all the power in the ground
- different drivers
- wheel spin? The time lost in 0-100 is bigger in comparison with 0-60 in the stock FD2. At least in a long run the SC with traction should have catch the time lost in 0-60
- bad launch
aka Paul
I expect SC is referring to one that's been supercharged, yes. I would expect a 0-62 time of well under 6 seconds, but as you say there are many factors.
Got the times after many attempts of not wheel spinning.
0-60 5.58 0-100 11.21 and v max 162.5 there was maybe 1 or 2 more mph but it was round 8.500 screaming so I backed off.
My mate brought his oem fn2 around today champ white 09plate so I think I'm right in saying it has a diff as standard.
0-60 6.86secs 0-100 16.05 secs
As you requested 30-70 times fn2 5.98
Fd2 30-70 4.51
For the record the FD2 was last dyno was @ 375 wheels.
Due to hot weather.
It was mapped to this power winter times it jumps up 1.5 psi running 400+ wheels
I misread and thought that the bad times in the 1st post, were with your car.
I need to learn to read [smilie=hammerit.gi:
