1 - 20 of 21 Posts
A new clutch as fitted by Honda....
started to slip over the weekend so just preparing myself for the pain...
Discussion Starter · #7 ·
£600 approx mate.
Pay a little more and get a CG Motorsport with new DMF fitted for around £800
Thanks for the replys people:D
can you advise :-
Where are CG Motorsport ??
Do they do same day fitting ??
the purpose of the DMF ?? - my car is a standard Type S 2.2, how will the new DMF help ??
Again thanks for your help !
Ian
+1 for CG.
They are based in Leeds and fitted mine in about 5 hours just give them a bell.
can you advise :-
Ian
The DMF or dual mass flywheel is fitted to make the clutch actuation smoother & because of the large amount of torque the CDTI engine produces so I believe, please correct if i'm wrong anybody
Cockup Specialist
It dampens engine pulses of the pistons.
The higher the engine torque and the lower the number of cylinders the greater the pulse.
The engines more stable at higher rpm but at low rpm they make a world of difference.
Reactions: Xrv750
yep is 600quish, im waiting to hear back from dealer as to if they will cover my clutch under warrantee or not!
if not apparently im going to have to pay
I've got a 2006 2.2 CDTi. The clutch slips (mainly) if I load the engine whilst moving, say for example accelerating from about 50MPH in 5th gear.
So far as I'm aware it's a standard EX and hasn't been chipped. It's done 80k. I was thinking of trying for a good will warranty claim but doubt this will wash with Honda. Should I simply replace the clutch or should I consider the DMF at the same time? I don't really fancy splashing the best part of a grand on the car :(
d
How is anyone supposed to get their vehicle to Leeds if their clutch is already rooted
Just askin
I believe it's a case of the slipping getting worse and worse when you boot it under load at around the peak torque area. I have read on these here boards of people going for months like this before replacing so it sounds if you're sensible with the clutch you can still get plenty of miles out of it still before you're stuffed.
1 - 20 of 21 Posts
