1 - 12 of 12 Posts
Gaz
As title really? Is it a case of unplug old and re plug new?
Or is it more complicated than that? Do I have to worry about immobilisers etc?
Thanks, Gaz.
#MrGrumpy
Be prepared to lose your stored radio stations, and I'd advise not having the key in the ignition.
Otherwise it's a basic swap.
Marty says BWAAAHHH!!!
Had mine disconnected a couple of times and thats all I had to do. Radio stations are not lost.
What battery did you go for as mine is hesitating on the cold mornings so think it is on its way out.
I brought myself a volt meter to check the battery. I replaced mine after 4 years as it wasn't holding its charge as well, and went for another Honda battery. Honda have upgraded the battery and the new one doesnt have a wellness check, but its supposed to be better?
regrets his username
Yuassa 053 is perfect for this cold weather ;), has health check on top but when fitting don't refit the plastic battery casing else the positive connector will just pop off no matter how tight you do it
1 - 12 of 12 Posts
