stumbled across this
Honda - Civic Type R - Front 4 Piston kit CP6637-1002
Black Caliper Kit Number - CP6637-1002.CG8
Red Caliper Kit Number - CP6637-1002R2.CG8
IMPORTANT NOTE:
Before purchasing or installing a formula big brake kit, make sure that the brake upgrade is suitable for the make and model of the vehicle, and that the wheel has been checked for clearance by downloading the caliper profile drawing PDF using the link below.
Download pdf format caliper installation profile to confirm wheel clearance here & exploded view here.
Model Year 2007 on Brake Caliper Type CP6637 Brake Disc - Drilled N/A Brake Disc - Grooved CP3580-1180/1CG8, Ø330 x 26mm / 48 Vane Brake Disc - Plain N/A Brake Disc - Strap N/A Brake Pads CP6627D51-DS2500 Wheel 17" Aftermarket
Discussion Starter #2
bump
AP do some quality stuff, interesting, thanks [smilie=gt-happyup.:
should have a price by the end of the week
New Honda Civic type R (2007), AP Racing front brake kit
Part # CP6637-1002.CG8 ( black calipers) List £1483.79
Part # CP6637-1002R2.CG8 ( red calipers) List £1509.64
Involves
4-pot road spec calipers.
Ø330x26mm 2 piece discs i.e. bolted to alloy bell centres
Ferodo Ds2500 fast road / track pads
Standard hose adaptors
High temp fluid
Caliper mount brackets
All mounting bolts etc..
Reactions: kahmed87
where can i order one?
