1 - 2 of 2 Posts
"Boards don't hit back"
Hi all,
Has anyone used this before, just had an email through from powerenhancer with it on offer.
This is the description:
AR6600 is a powerful, dedicated cleaner for turbochargers on turbo-diesel powered engines. The unique formula contains a patented blend of molecules that are activated during the combustion process, rather than destroyed like many conventional fuel additives. These molecules bond with post combustion carbon acting as a catalyst to effectively and safely remove deposit build-up.
AR6600 will also help clean the DPF and catalytic convertor thus quickly restoring lost engine performance and fuel economy resulting from deposit build-up in any of the post combustion areas. Harmful exhaust emissions are then reduced. AR6600 is compatible with all turbo diesel engines and diesel fuels including pump, bunkered or bio-diesel blends.
Any ideas on this or equivalent products that you can recommend are all welcome.
Cheers guys
1 - 2 of 2 Posts
