1 - 12 of 12 Posts
Hi everyone, I'm new to the forum and just got my FN2. I'm planning an audio upgrade very soon and have the following ready:
Impulse Double DIN Fascia full kit with Pioneer patch lead
Pioneer AVH-X2500BT (not bought yet but looks the best)
Astra Speaker adapter rings (6.5")
HERTZ energy ESK-165L 6.5" speakers for front (with tweeters and crossovers)
Infinity Basslink 200W 10" powered subwoofer (with leads as this was installed in my previous car)
This is my first major car audio upgrade so have I missed anything and will this sound good?
Anyone done something similar hazard a guess on how long to do this in one go? Is it worth paying to have it done?
No Smoke no poke
looks good to me, you should get much better quality from this little set up
depending on competence you should set yourself a full weekend or spread it over a couple
only things i would add would be a reverse camera ( wouldnt be without mine now)
Sound deadening for the front doors too, while you have the cards off its well worth doing better sound and less vibration.
D and A said i did it
Just fitted that head unit a few weeks ago and took about 2 hours start to finish, first time ive had the dash out and it wasnt as bad as i was expecting, descent trim removal tools make it easier. I bought that head unit month ago as the 2600bt is this years model and is around a £100 more so i would buy the 2500bt quick, as far as i can tell its exactly the same bar a few cosmetic tweeks.
Might want some 6.5" coaxials for the rears if your going all out and some dynomat / soundproofing.
Great thanks, can you recommend a reverse camera and something to sound deaden the doors with?
No Smoke no poke
Mr bozo's cameras get good right ups, personally i went with one off ebay cause i liked the metal case finish although it hasnt faired well with the salt, personally id go plastic.
As for the proofing you can not go wrong with dynomatting but again personnely I think for what it is its over priced and bought as have many off here from these guys Car Sound Deadening Pads x 10 530mm x 190mm x 2mm | eBay
Awesome thanks, how many of those x10 packs did you need?
Thanks for the heads up, I've reserved one. I'm not going to bother with the rears, I'll fade them most of the way down.
I havent changed my speakers yet and the stock speakers sound much better with a proper head unit, i will change then eventually though as they are better but not great!
Dervinator
Two Bojo trim removal tools are a must. Also buy some spare door popper clips (Millfield Autos) as you invariably will break one or two especially in winter (brittle)
Also bare in mind you bought a sports car (FN2) so don't go overboard with too much sound deadening as it's heavy dood !
Thanks for the tips!
Yeah I think I might skip the sound deadening - I don't think it's needed anyway.
I have the headunit in now, I should be doing the sub next weekend and possibly front speakers then too.
Discussion Starter #12 (Edited)
I've progressed with this and have installed the impulse double DIN fascia with the Pioneer HU and the Infinity Sub (bolted to the back of the rear right seat as it was too big to fit in the lower enclosure as I had hoped). The sound has greatly improved :).
I do have a couple of problems with the headunit though - The cage didn't fit all the way through the fascia even when I filed the plastic lips back. You can see the cage slightly from the passenger side - is this normal? There doesn't seem to be any way to attach the cage to the fascia so if it did fit all the way through it wouldn't sit in place.
The other issue is that the steering wheel controls don't work. Is this an issue with the HU not supporting them? Where should the patch lead connect onto the HU back?
Also the bojo trim tools are excellent - only needed one so far.
1 - 12 of 12 Posts
