Full beam takes an age to kick in. I drive on dark country lanes and thet simply do not come on quick enough. My wife has a DS7 the auto lights are amazing
anybody else o4 any fixes?
Interesting, No problems on mine. They are spot on to go off and a bit slower to come back on but at least I am not blinding anybody and it is maybe a 1-2 seconds after they could be turned on if maximizing it manually.
Mine don't dip when going around some gentle curving corners. They do dip eventually, but when you have a car visibly coming toward you and your car doesn't immediately dip, it does feel a bit rude.
Mine don't dim as quick as I'd like, it takes a while for it to recognise an oncoming vehicle.
Interestingly though, I had a bog standard 19 plate Jazz as a courtesy car last week, driving home from work at 11pm and the auto headlights are perfect. High beams switch off near instantly when there's an oncoming vehicle.
That's routinely the 1st thing I 'disable' when I fire up.
Perhaps it's the LED lamps, but I've found it reacts quite quickly.
If I were to be in a rural area / driving at night, I'm fairly certain I'd be testing it out at least.
Al.
I’ve had no problems with it and they work a treat for me on country lanes, but do Check the camera/sensor is clean as that can impact sensitivity according to a Honda mechanic from my local dealer. It’s located behind the rear view mirror.
