my auto idle stopped working in january so had a new battery installed and it was working. At the moment
im on furlough from work so am only driving about 5 -10 mins every couple of days, and now im getting the low battery sign when it shows auto idle wont work, any ideas ?
thankyou
Hopefully it should recover once driven; you could look at getting a charger - connect positive to positive, and negative to the chassis and the car will detect the charge, and allow you to use auto stop.
Sent from my SM-N975F using Tapatalk
It's working as it should taking account of a low battery. If you have a garage good thing to do would be to put the car on trickle charge when your not using it.
its working now took it out for a 30 min drive
Only a temporary fix if your not using the car. You will have just have to live with it until things get back to normal. Funnily enough there are those on this forum, wanting to shut it off permanently. Personally I like it.
