noticed a bad odour when i first put my fan on, it goes after a bit and seems ok with fan off, could the pollen filter need replacing?
"Grandad eye"
Is it the air con or just the fan?
If you've left the AC off for a long period of time and have only just started back using it then that will be the reason for the damp odours. The smell will go after a bit and if you leave your AC on constantly then you will notice you no longer have this odour when it first comes on.
Hope you get it sorted ;-)
Not had the a/c on for a long period of time ie over the winter, however not noticed it with the a/c on, just seems to be with the fan on a cold setting, maybe it's some decomposing leaves in the ventilation system
