Hi guys!:confused:
I have to change the left front ball joint and I am in a big problem. I order a ball joint
but when I check the arm it doesn't have the 3 fixing holes.
Here you have a picture of the actual part that I have to change on my car.
I would be very grateful if you can help me asap with an advise as I have to pass asap the car inspection. I should look for a different part or I have to change the entire arm?
Looking forward to your answers!
Just for the sake of saveing some hamering the arm from the wheel, i used a hot fan blower and heated the ball joint screw , sprayed it whit wd40 and bang one time whit a hamer and it felt right of the first time, before that heating i was banging on it like an idiot and it didnt came off :))
But i wouldnt recomande heating the nuts on the arm .
