Is this plug and play with Nav units and xcarlink installed?
If you get it from honda with all the cables, one should however mention that it's not worth the money they're asking, not even close.
This thread's a bit old but just to confirm I just fitted an Xcarlink to my car which already had the Bassworks kit and it all works fine. The two don't even use the same connectors to the head unit so there are no compatibility issues.
Rather than spending money on a bassworks amp, get yourself a double din instead. Will sound better and give you tons more options.
No point in doing the double din in an EX as id lose the factory sat nav
