1 - 10 of 10 Posts
Hi
Bought my Civic about 3 months ago. All ok, but about 2 weeks ago auto stop-start began to work intermittently. Instead of working it'd show an A with line through it. Sometimes it'd work, sometimes not.
Then it started showing the A with a battery sign. I figured battery was on its way out and wasn't good enough to handle stop-start. Yesterday on a frosty morning car wouldn't start, figured time to get battery changed. Halfords recommended their HB005 battery, so got one of those. Fitted it, it starts fine now, but stop-start not working at all. Still showing 'A' + battery sign, plus there's now a permanent warning sign on dash that stop-start isn't working.
Is this battery not a good match for cars with stop-start? If so what is the recommended? Previous battery was a "Varta StopStart 70ah 620a"
The new Halfords one says 60ah, not many other details.
https://www.halfords.com/motoring/bulbs-blades-batteries/car-batteries/halfords-hb005-lead-acid-12v-car-battery-3-year-guarantee
Thanks!
Ah, The battery they seem to have sold you is far smaller (In terms of AH / CCA) and is also traditional lead acid; and not compatible with stop start.
For something rather more robust, I'd recommend an AGM Battery:- https://www.halfords.com/motoring/bulbs-blades-batteries/car-batteries/halfords--096agm-start-stop-agm-12v-car-battery-5-year-guarantee
Is what I've fitted (It's the size used for the 2.2 Civic) - You may have to remove the plastic battery tray, but the regular holddown will fit over the battery without any trouble.
Oh, and to expand on my previous:- The Varta batteries (OEM) don't seem to last very well; I had to replace mine after 2 years - They are EFB Batteries, which are not as resistant to deep-cycling (i.e. Stop start use) as AGM Batteries - So whilst it costs a fair bit more, It's probably worth looking for an AGM Battery.
Thanks for the replies. Taking the battery back to swap it. I usually turn stop-start off, not a fan of it.
The Varta batteries are guaranteed for three years so maybe you should have taken it up with them if it erxpiured after two.
I was considering putting it in for the service to get a replacement, but in the end I didn't bother
Sent from my SM-N975F using Tapatalk
1 - 10 of 10 Posts
