Loaded voltage and hydrometer are the standard health checks. The battery is behaving ok. It is over 5 years old now.Testing a car battery voltage isnt that good of an indication. I would'nt replace it because the voltage is a bit low. How is it acting? Causing any problems? Not starting in the cold? When tempertures are lower the chemical reaction is slowed so if your battery survied the w
inter It should last the summer.
Exactly. I think i will wait for it to play up one morning. The voltages suggest it has some life yet.If it ain't broke..................
Quite agree, you can tell alot from these tests.Loaded voltage and hydrometer are the standard health checks. The battery is behaving ok. It is over 5 years old now.
I assume that is unloaded or engine running?My new battery - over OBD2 reader was 14,4 highest and 13,6 lowest...
