Hi all, I recently bought MK8 Civic and I'd like to change the yellow headlight bulb.
Could someone recommend a best 6000K bulb upgrade, please? Something that won't fail MOT and compatible. Thank you.
i-Vtec
There isn't one. Regardless of what it says on the packet 6000k is not possible with halogen bulbs. JMO but buy LED, crank the headlight aim down a couple of notches using the adjuster on the dash board and just swap you bulbs over for the MOT. Its what I do anyway.
What Das says, easy enough to adjust the aim correctly using the headlamp adjusters on the headlamps themselves too. There was a recent post on how to do it.
i-Vtec
Heres the How2 on how to do it at the headlights, but as long as your lights are ok and level there should be no need to adjust them using this method.
