I think I’ll go Pagid discs and Pagid pads. I’ve heard Brembo don’t make their own pads. I usually go mintex but aren’t they the same company as Pagid? TMD friction?go Pagid for the discs, Brembo pads are fine.
I work for ECP and our manager says we get a lot of warranty claims on Brembo discs.
I had Mtec grooved and dimpled discs all round on my previous car, a Golf R32. Can't say I would get those exact ones again, they were quite loud even when not under braking and didn't inspire much confidence for regular driving. The grooved or drilled only ones should be ok though.Anyone had an experience with mtec brake discs?
They use Mintex pads on my company car they are good pads seem to last a long time.
ShameI can’t seem to find them Akebono pads in the UK. Any good Ceramic alternatives to the Akebono pads?
i had m-tec on my 2.2 drilled and grooved done a lot of miles no problemAnyone had an experience with mtec brake discs?
Yes I had them on my Gen8. The fronts were fine but by year 2 and 15K the rears looks liked they had been on for 10 years and 100k. I wouldnt go with them again. I had mintex on them with no issues.Anyone had an experience with mtec brake discs?
I work for ECP also lolgo Pagid for the discs, Brembo pads are fine.
Thanks for the feedback, how long have you had your rotors and pads on? Just for context the 'warping' of rotors is generally unseen, and it is more often pad deposits or uneven wear creating a lip (generally seen when changing pads and keeping rotors), both of which can feel like warping under braking. Pad deposits can be removed by turning rotors using a pro cut lathe at your local garage, or often can go over time with continued use. just something to considerI had Mtec grooved and dimpled discs all round on my previous car, a Golf R32. Can't say I would get those exact ones again, they were quite loud even when not under braking and didn't inspire much confidence for regular driving. The grooved or drilled only ones should be ok though.
I currently have EBC Ultimax Slotted discs with their Yellowstuff pads on the Type R. No complaints on these and have heard good things about the Greenstuff pads (less dust), but never used them myself. The discs are a bit steep, and sadly mine have warped a bit. So i'll be replacing them with some Mtecs in the near future as they are about half the price of EBC! I probably won't change off EBC pads though.
The current method is to use the black thermic coating to prevent rusting on all areas of rotor that are not within the pad sweep area, as the pad is used it will remove the coating from the friction area which can then rust, but this rust will also be removed by the pad during use.I just replaced my OEM front pads with Brembo (I kept the OEM disc as they were not that worn).
Man do they stop the wheels from turning. It’s actually a little too much for my taste, almost difficult to brake lightly..
I’m running Pagid pads + OEM discs on the rear. Didn’t feel much change from OEM when I changed them. They took a bit of running in though.
I would try EBC yellowstuff next time I think… I’ve heard good recommendations. But I could go for either Brembo/Pagid/EBC depending on price and availability when I need them
Theoretically you need better friction in a pad if you go for drilled/slotted discs, which might explain why the Brembo pads have extra grip on a plain disc.
I’ve heard people complaining about noise from drilled/slotted discs so never had the courage myself to go for these..
I got the EBC coated discs on another car a few years ago, the rear ones have started to rust, so I guess the coating only temporarily improves the look.
And a little tip for running in new discs: Try to avoid stopping the car completely with warm new discs. Try to always keep it rolling a little during bed-in. This will prevent pad material to build up in a single spot on the disc, which could make it feel like you have a warped disc.
I've had them on since October 2020 and done about 7000 miles (mostly low speed, some motorway). I only say "warped" as it was driven by someone with rally experience, and that's what he said. I didn't know it could just be pad deposits. I'll get it checked when it's next in the garage. Thanks for the info!Thanks for the feedback, how long have you had your rotors and pads on? Just for context the 'warping' of rotors is generally unseen, and it is more often pad deposits or uneven wear creating a lip (generally seen when changing pads and keeping rotors), both of which can feel like warping under braking. Pad deposits can be removed by turning rotors using a pro cut lathe at your local garage, or often can go over time with continued use. just something to consider![]()
Warping is a general term used or a misconception by many people, I myself would also assume so much before working for EBC Brakes as the words 'warped rotors' was so often spoken. Truth is, if the brakes get extremely hot and are then held on the rotor for some time, part of the pad gets deposited onto the rotor and this is the shuddering/ vibrating feeling when braking.I've had them on since October 2020 and done about 7000 miles (mostly low speed, some motorway). I only say "warped" as it was driven by someone with rally experience, and that's what he said. I didn't know it could just be pad deposits. I'll get it checked when it's next in the garage. Thanks for the info!
