What products would you recommend for cleaning and protecting metal trim items such as an aluminium fuel cap and door sill garnishes? :D
just your normal wax/sealant products pal. i never use an abrasive on them
Stephen
If you're cleaning something that is grimey (e.g. exhaust triangle trims) then something like Britemax Twins or Autosol with a very fine grade of wire wool will do the trick. Otherwise using a microfibre with some metal polish will be more than sufficient to polish metal surfaces.
I the personally seal things with Blackfire Metal Sealant - just makes cleaning that whole lot easier in future and makes things wipe off with a microfibre and metal polish rather than fine grade wire wool.
I use quite a few AG products, so had a look at their metal polish. The door sills etc are pretty clean generally so keeping them looking shiny and protected that I'm hoping for :D
