You don't HAVE to have those but if they are fitted then they MUST work correctly.
You have to have them by law.You don't HAVE to have those but if they are fitted then they MUST work correctly.
Lots of fud around about this atm.Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
Think it's coming in next month?Not according to the MOT manual.
HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective. Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
