1 - 20 of 43 Posts
Does anybody know what's best for spraying the back lights I'm doing a outline Matt black or possibly Matt black or even smoke black question is do I need special paint
or need primer ,then paint,then top coat to seal the paint onto the plastic!
Cheers for any advice
Sent from my FIG-LX1 using Tapatalk
Tint Spray, you can get it on ebay about £8 a can, its very thin so advise not to do it in situ and remove the lights from the car or you will get lots of runs. Get 2 cans to be sure and just do light coats. If it goes dull which it can sometimes then you need to remove and start again or sand and polish it.
Also get the remover spray too incase of errors otherwise you will have a right job getting it off, not impossible just takes 10 times longer.
I'm doing it to go around my led conversion tail light I've used tigerseal to seal it up looks ok as the misses was saying I think she's be polite lol only a tad blotchy where the cutting disc was slightly rougher not smooth don't get me wrong it's sealed . Just want the outline edge to look neat tidy I was thinking originally vinyl then though erm spray then erh vinyl getting stuck on decisions???
Mask it up, key it with scotchbrite, then give it a coat of plastic primer, topped with black paint. Halfords will do, it's only a thin section so getting a nice finish will be easy :)
I did have that in mind what's your opinion Matt black or gloss and do I clear lacquer the whole thing once done
Used 5 coats of e-tech lens tinting kit to spray my rear centre panel, comes with a tint remover in case of mistakes.
Bloody hell cool that's alot of masking off I may use this tape I saw that e-tech tinting kit very tempted do the centre part and do the outer parts on side lights and tail lights?
Moderator
ddkirk2016 and tricky. You are talking at cross purposes. Tricky tinted pretty much the whole lot and ddkirk is painting the outer edge.
Paint it gloss black. It's pointless painting it mat black and then over-painting with lacquer.
Masking? Old newspaper to mask the middle with 4 strips of masking tape to get the edge and hold the paper in position.
Discussion Starter #16
M8TJT yeh gloss is good but.. which type ? For plastics? Plastkote ,etech, do I need to primer first? Yes long winded but...I can't find dam answers on Google?
Discussion Starter #18
Just gone to check my light f£cking hell tigel seal didn't hold grhhhhh been a week but didn't sand the perspex peeled right off what will stick this bugger ..
1 - 20 of 43 Posts
