1 - 13 of 13 Posts
Hi, pretty sure my radiator needs bleeding as im getting hot and cold air intermittently when ive got my heater on 'Hi'
Does anyone know how to do this?
thanks,
To bleed the cooling system
Remove the radiator cap, put a funnel in the neck of the radiator, set the A/C to Hi but keep the fan off, set the A./C to fresh air and run the engine at 2500rpm till cooling fans kick in.
Simple as that? when you say A/C to Hi, do you mean just turn the dial and leave it?
So if i was to press 'off' first, then turn the dial to 'Hi' ?
無限 Unlimited
Turn A/c on then set temp to high.
Setting it to high temp fully opens a valve that circulates the engine coolant around an extra loop to the heater matrix, that way you can bleed the air out the whole system.
Laney is correct.
But make sure you set the heat to high, turn off recirculate and then turn off the A/C
The coolant goes into a heater core and the squirrel cage fan blows air into it which comes out of the vents.
The heater core is like a mini radiator
Which is why if you have an old bomb that is overheating you get told to run the A/C on hi to help cool down the car.
Birlliant guys, and this should get rid of any air bubbles? how do i check if need more coolent? is there a dipstick like oil?
fingers crossed!
Have the radiator cap open and the level in the radiator will drop, keep topping it up or else you will introduce more air
1 - 13 of 13 Posts
