1 - 10 of 10 Posts
Hi
Just a quick question - the OH was out in the car last night and reported that the heater wasn't working. Tried it this morning and it seemed fine - for about 2 minutes - and then it shut itself off.
I noticed that the motor sounded a little noisy, but other than that it seemed fine - I was able to change the fan speed and adjust which vents were getting air whilst it was working.
Obviously as it was working, then not working, then working again, then not working agiain, I've ruled out the fuse and am assuming it's some sort of self-protecting behaviour? I've not checked the filter but it's no more than 12 months old. It's a pain to check because the little clip that holds the cover on has was snapped when I got the car, so the cover is taped on.
My initial suspicion is that it's the motor noise that's the clue - although it was no more than 'a bit of a whine' rather than sounding like it was on it's last legs. I understand that access involves taking the clutch pedal off (is that for RHD cars?) and a fair bit of disassembly, so before I do that I'd like to be more certain as to what the actual fault it - so, if I take it to the garage, is there any chance any more detail will come up on the scanner (not keen on paying for a diagnosis if nothing is going to show)
Any other avenues to investigate much appreciated. Of course it's packed up just as it's getting cold!
Thank you! This is why I love forums - I read all that when I got my first Civic and had forgotten all about it!
I did the first diagnostic test first as that seemed the most sensible one to start with :)
Ignition OFF / Press and hold down the A/C system's Auto and Mode buttons / Start the engine / Release the buttons
All the readings seemed sensible except for
9th sensor: vent output air temperature C which the car seemed to think was 38 degrees - which would seem unlikely given that it as 9 degrees outside and the car hasn't moved for 9 hours.
While is was in reading 9 the fan came on fully as well.
With the other test - Ignition OFF / Press and hold down the Auto and Re-circulation buttons / Ignition into II position / Release the buttons
I just got 88 88 which alternated with a single segment (the lower right hand edge of the last 8 iyswim)
So it looks like it might be something to do with a rogue reading from vent output temperature sensor? Does that sound like it would trip the system to off? I know where the cabin temperature sensor is, but I have no idea where the vent one is - any info would be much appreciated.
Thanks again.
UPDATE - I thought I'd go and make a note of the other sensor readings for the sake of completeness:-
1st sensor: Cabin temperature C - 12
2nd sensor: Exterior temperature C - 10
3rd sensor: Solar radiation sensor value (Dark=00, Flashlight=04, Cloudy=10, Sunny=65) 1 (night, but parked near a streetlight)
4th sensor: Temperature of the air exiting the air conditioning evaporator C - 5
5th sensor: Drivers air mix opening (low value indicates cooler air distribution, higher value indicates warmer air distribution) % open - FO (fully open?)
6th sensor: Passenger air mix opening (low value indicates cooler air distribution, higher value indicates warmer air distribution) % open - FO (fully open?)
7th sensor: Mode positioning % open - 26
8th sensor: recirc flap % open - 00
9th sensor: vent output air temperature C - 75 this time
On the second test it just did 88 88 and then nothing - although the fan continued to work while I was in the car for a few minutes.
As a further update, OH said the heater was on for about 5 minutes this morning and the fan was going at full speed all the time - but that might be because I had set it to full speed manually when I was messing with it the other night and she hadn't noticed it wasn't on Auto.
Looks like the vent sensor is going faulty. I had the cabin temp sensor fail intermittently which causes similar issues. I will have a look in the Haynes and see if I can find a location for you.
That would be awesome if you could - thanks.
Apologies for the late reply - I've been moving house so I've been quite busy and without internet.
A belated thanks very much for this - house move has been utter chaos so I've not been online much. Fortunately the car has behaved perfectly since the few incidents when I first posted, so touch wood it was some sort of temporary software-glitch or a stuck bit of leaf somewhere or something.
(and please don't let it fail again when it's properly cold!)
Put the heating system into diagnostic mode when its not blowing and post the results. Instructions are in the wiki at https://www.civinfo.com/wiki/index.php/Climate_Control
In particular, what temperature is the cabin temperature sensor saying.
Can you please send this link again because it doesn't work.
Northern Soul, did you fix this problem with the blower?
I have the same and already replaced flap motor actuator and the heater blower motor fan from other car but it doesn't work again - when I start the car and press the button it starts only for 5 seconds (I hear the compressor) and then stops without blowing hot or cold...
Can you do me a favour please? Remove the aircon relay from the under bonnet fuse box and leave the car overnight. Then see if the heater works normally the next day and report back.
There are 2 diagnostic tests which I have listed below
Sensor check
Ignition OFF
Press and hold down the A/C system's Auto and Mode buttons.
Start the engine
Release the buttons
On the A/C - Radio display you'll see the sensor number and the value for that sensor.
Press the heated mirror button to advance to next sensor
1st sensor:*Cabin temperature*C
4th sensor: Temperature of the air exiting the*air*conditioning*evaporator C
7th sensor: Mode positioning*% open
8th sensor: recirc flap*% open
To check for HVAC fault codes
1. Turn the ignition switch OFF.
2. Press and hold the recirculation control and rear window defogger buttons, and turn the ignition switch ON (II).
3. Recirculation indicator turns on for 2 seconds, then self-diagnostic function begins.
NOTE:
•The blower motor will run at any speed during the self-test regardless of the dial positioning.
•In the case of multiple problems, the recirculation indicator will blink the lowest number DTC only.
•If no DTCs are found, the indicator will not blink. DTC (Recirculation Indicator Blinks) Detection Item
Error codes are below
1 An open in the air mix control motor circuit
2 A short in the air mix control motor circuit
3 A problem in the air mix control linkage, door, or motor
4 An open or short in the mode control motor circuit
5 A problem in the mode control linkage, doors, or motor
6 A problem in the blower motor circuit
7 HVAC control unit internal error
8 An open in the evaporator temperature sensor circuit
9 A short in the evaporator temperature sensor circuit
1 - 10 of 10 Posts
