1 - 19 of 19 Posts
The bluetooth in my 55 plate EX 2.2 is not finding any phones.
Can somebody confirm that this (attached picture) is the offending module and if it is where can i get a 2nd hand one?
Graham
Discussion Starter #2
Been quoted £881 for this from my local dealer (Parks, Hamilton) and they don't actually have it showing up in stock.
Does anybody know of any breakers who are breaking civics at the moment?
not got it too hand but looks very much like the one i just had replaced under warranty think it was 620+vat +2hrs labour to fit and code to the car but i cant be sure exactly as the warranty company got billed direct
its behind the panel where your right knee would be.
dunno where they get 2 hrs from because it takes about 5 minutes to get to unit
glen
I drive my Mistress...
Look on EBAY for civic breaking and e-mail the sellers direct with what you are looking for. Hope you find it mate!
i just bought the module on ebay stock no h39770smre01,, £225 off a breakers yard,,bought the car from a car sales 3 weeks ago bluetooth hasnt worked since i had the car, they booked it into honda for me to rectify,,,ouch £800 for the module honda quoted,, the garage i bought the car refused to pay for that part and offered to put a after market one in for me,, i wasnt happy with that so i went on ebay to source one out,, i have a 2006 ex model,,,they happy to reinburse the money and them fit it,,, but dunno if it has to be coded by honda or will it be simple to change over? i going to leave it with the car sales,,, because honda will not fit 2nd hand parts,,,can this part be changed by anyone?
If you were near me, I did fit for you for free... it takes 5 mins and does NOT need coding to the car (I've double checked in the Service Manual - this is just dealer bull!)
All you need to do is remove the triangle trim at the end of the dash (drivers side)
http://www.civinfo.com/forum/attachments/how/573d1159339169-how-get-into-dash-img_6401.jpg
Now unclip the dash panel that goes all the way under the steering column, by pulling gently towards you... it wont come all the way off because the HFT unit's cable will stop it... un-plug it, the remove the panel. The undo the 2 screws holding HFT unit onto the panel and swap for the new unit :)
Re assemble and job done :)
I just bought one from a breaker for £84. Give them a try
A1 Jap Spares
0161 682 2221
Mine had a white label, was given the choice if I wanted one with a white label vs pink label.
I opted for one with a pink one and its worked perfectly.
Plus was give 2 months warrenty.
Also if you we're near me, would be happy to help.
The images Bog gave is basically most the job.
Just open the panel on the right
Remove the single screw
Unclip the panel under the steering
The module is directly behind that panel
Just unplugs with that green adapter
Give them a call and see if they have any more.
When I got mine last week they said they had a few and if it didn't work they would exchange it.
Obviously try talking them lower then £84 as you know they will sell at that price.
Another poster on here got one from EBay for £25, I wasn't ever able to find one that cheap but £84 with warranty I'm happy.
Any problems/help needed when installing it send me a private msgand I can give you my number and talk you through it.
A1 Jap Spares
0161 682 2221
They are total rip off merchants, tried telling me they are cheap and wanted £300 for the module. According to them Honda charge quoted £1800!!! when I've been to the dealer and they wanted £900 all in (dear i know).
Probably didn't know too much about it when they sold it to me. My module is still running strong.
There are breaker yards available on a google search. Put the details and it gets sent out to loads of breakers to qoute you on the price
Question,
Wouldnt it be possible to switch bluetooth module from newer civic to 8th gen civic?
I hope newer civic have bluetooth streaming and better sound quality?
Done just that & got one for £74 including delivery via courier. Will attempt to fit it today & hopefully have some good news to report.
Fitted the hft module, all working perfectly fine, not bad for £74 compared to honda's £900 and labour charges.
Took about 10 minutes to do. Downside all saved numbers needed to be added again.
Some questions posted on various forums regarding hft module:
- No it doesn't matter whether the module has white sticker or pink (the one i bought had a pink)
- No it doesn't need coding by honda for it to work
Any other questions feel free to ask.
Also a big thanks to everyone on civinfo - your tips and advice have been very useful.
When pressing the hft buttons I get no phone commands and my phone does not see the car, the voice control commands for sat nav etc work fine. Checked the accessory fuse and that is OK and cig lighter works fine. Does this sound like the BT module has died?
I had this problem. Before replacing the module check it first.
I removed my hft module (pink sticker) checked the plug wasn't loose then I noticed the module opens pretty easy.
So I opened it up couldn't see any scorch marks on the circuit boards.
There are 2 boards held together by a grey plug. I pressed the boards together again and plugged the module back in to test it and it now works again.
Maybe worth trying before outlaying any money.
1 - 19 of 19 Posts
