sorry if this has been asked before but i'm in desperate need to find out if the Bola B1 18x8.5 et 45 will fit the fn2, its not lowered either.
Ive checked that it will stick out by 22.7mm further than the OEM and 2.7mm inboard than the OEM.
does anyone have these or 18 x 8.5 fitted?
cheers :smile3:
Enjoying life
I have 18x8 et45 fitted, lowered 15mm and it's fine. Yours will be 6mm extra on each side of the rim.
I believe a few run et38 on an 8j rim?
They will fit but youll have to put on a slightly wider wheel to go onto the rim of 235 as 8j the minimum width of a pin is 225. If this happens your speedo may be slightly out of range
Im running 17X8 evo wheels ET 38 with 225/45 tires. No rubbing, on MeisteRrs, i think the car is lowered by 15-20mm.
