Hi all,
Picked up an OEM spolier today off this forum and I think I've decided to bond as opposed to drill and bolt as it didn't come with the end brackets. The adhesive of choice on here seems to be silkflex 255f I think.
So now for the silly question, where is the best place to apply the adhesive? Do I remove the thin foam tape from the underside and apply a bead in its place or do I leave the tape in place and run the bead along the inside or do I need to do something else?
Also I assume I apply adhesive to the four circular sections where the bolts would normally fit.
Any advice would be gratefully received as all the how tos I've found have pics removed.
