What's the normal boost mean't to read on the dash as mine reads 1.7 at max sustained boost it peaks at 1.8 x100kpa . I've read online and this is 24.6 to 26 psi Is this standard as it seems alot or has It been mapped before ?
CW GT
Ok I have her back I'll check my displays for you, 1.7 rings a bell tbh but I will verify
2010 Milano Red FN2 Type R GT #R22063
Is it possible the issue isn't that you're getting 1.7, but that maybe your friend has an issue whereby he is getting less boost than he should be (assuming both cars are in R mode)
Deluded FK2 Owner
It fluctuates; presumably due to outside temps, humidity etc. I've seen as low as 1.2 and as high as 1.7 on mine. Typically see 1.6-1.7ish on summer mornings; no idea why. I have a t-value mod done on mine, just to note, but I saw this before that also.
