1 - 9 of 9 Posts
Hello :) I have a "little" problem with trunk door. I can not open it.. It opens very slightly on one tooth and can no longer.The central lock works fine - unlocks and locks.Any advice?
I tried this and the result is the same..Any advice?
i-Vtec
If you drop the rear seats there is a cover in the door cover you can remove and tab behind that allows you to open it manually with a screwdriver.
Hi Das and tanks for help. I removed the cap but did not see where to push with the screwdriver to release it. I tried only with the handle on the machine to open it but the problem is not in the central locking, obviously mechanical.where to push to release the grip on the door?
i-Vtec
Its just a metal tab that sticks off at 90 degrees to what its attached too iirc. Ive managed it blind at the scrappies before, so it should be pretty obvious.
Discussion Starter #7 (Edited)
Ofc mate, I just hope you are right because it does not work for me and there must be another way.It does not matter if I open inside or outside.I hope to turn with screwdriver like you said :)
This way the picture does not happen. There's just something broken in the machine.
Okay....After 6 hours today, we finished with happy end :D The job is difficult, use a drill, you have to break the plastic. There is no other way to change this mechanism
That was the distance that the door was making, very liitle about 2 cm.The mechanism was broken into the second ring
https://www.civinfo.com/forum/members/mkilla-albums-civic-picture40078-20181022-100551.jpg
https://www.civinfo.com/forum/members/mkilla-albums-civic-picture40080-20181022-135748.jpg
https://www.civinfo.com/forum/members/mkilla-albums-civic-picture40082-20181022-135800.jpg
9 holes with the drill
https://www.civinfo.com/forum/members/mkilla-albums-civic-picture40086-20181022-161834.jpg
https://www.civinfo.com/forum/members/mkilla-albums-civic-picture40088-20181022-162723.jpg
And finally
https://www.civinfo.com/forum/members/mkilla-albums-civic-picture40090-20181022-162715.jpg
The job is difficult and you have to be calm. The plastic is broken but there are many second hand cars and this is not scary. Lubricate the machine from time to time
1 - 9 of 9 Posts
