I have replaced the original Stabilus boot struts with Kilen struts and I'm not satisfied with the results — the boot still doesn't open "on its own" (with a bit of help), and I need to pull it quite a lot in the lower 1/3 part of the range (feels like even more than before when I thought the original struts were failing).
On the webshop I bought Kilen on, both Kilen and Stabilus have the same spec: 465 N, 596.5 mm length, 221 mm stroke. But when I took Stabilus out, I've noticed that on them it is stamped 475 N — I don't think this 10 N of difference (2%) would translate to anything noticeable, would it?
Did I receive faulty struts, or is this hard-to-open behaviour expected (and the originals which I threw out were fine), or is Kilen a bad brand?
If the latter, on the same webshop I can also buy Lesjofors and Magneti Marelli for a similar price to Kilen. Stabilus struts are twice expensive (and rated at 465 N, not 475 N like the originals). Any experience with any of these?
I've tried to see if maybe some other car model has similar struts (preferably: same length and stroke, but a bit stronger force), but I couldn't find anything. Even Type-R has the same struts, even though it has a wing!?
I've found that you could put some Mercedes struts on 8th gen Civic, but I didn't find anything like that for 9th gen.
