1 - 20 of 28 Posts
Hi I am looking for new brake disks for my fn2 as mine are getting worn, I have seen these on eBay and wondering if they are any good as it seems abit cheap for all 4 disks with pads
If your not tracking the car they will be fine also get braided brake hoses too and good brake fluid motul 600 rbf i recommend
Sent from my Pixel XL using Tapatalk
Thanks for the reply and that's what am looking at as well, are the disks and hoses easy to fit yourself?
Also what brake lines would you recommend
I have drilled and grooved discs and have used them on track and they have not split or cracked
There is literally no point in buying drilled discs for a standard FN2. Grooved, maybe, just to deglaze the pads. But why risk a cracked disc when there are no benefits in having drilled?
I don't use drilled myself any more but used to run the same mtec discs and never had a problem,I no there have been issues in the past with drilled discs cracking but if he is only using them in the road the chance of getting them hot enough to crack is slim to none
I only have the fronts and stock rear discs with brembo pads with hel braided hoses and motul 600 rbf fluid, i used mtecs before that but warped them after 3000 miles but i do drive hard lol
Discussion Starter #12
I didn't realise there was another way to drive these cars
Would you not recommend Mtec? Mtec grooved only for all 4 is £117 fro Mtec website
Mtec are fine mate if not tracking the car on the road they work fine i ran them with ds2500 discs i only warped them on track
250bhp.... finally :)
Discs are just for bling really, OEM will work just fine on OEM calipers.
It's only if you're tracking the car do you need to worry about warping / cracking from drilled discs etc (unless you're REALLY abusing it on the b-roads ;) ) I've always gone grooved myself as I'd rather not take the extra risk of cracking having drilled for zero benefits. Again, shouldn't be an issue on the road however.
I've ran MTEC on 3 of my Hondas with no issues so I rate them.
I'd spend the extra money on decent pads and braided lines, OEM fluid is again fine as it's unlikely to get boiled on the roads but RBF600 is good stuff.
Discussion Starter #16
Think I will go for the Mtec grooved, can't complain for £117 for all 4.
I have heard grooved are pretty noisy have you noticed it?
I did, but only on harder braking really
I have buyed exactly the same KIT ... Next week I will put them on the car :wink3:
+ Goodridge Hoses and RBF600
1 - 20 of 28 Posts
