Hi all..
Ive just bled through my brakes as the fluid hasnt been done for a while..
i started on drivers front then moved over to passenger front ..
ive turned the car on before moving onto the rears and the fluid light cane on,( orange circle with water/waves in it ) the pedal feels firm and the reservoir is at the correct level, i even test drive around the block and seems fine?!
Any help with ve appreciated!
Cheers guys
Hi all..
Cheers guys
Was about to ask this same question, since its happening to me for few weeks now. Checked fluid and even added some but lamp is still beeping every time i hit break. Breaking seems same as before. Note that i replaced both disks and pads not so long ago, if that matter at all.
Re-bleed the system. How much fluid have you put in? 500-600ml?
I just changed my lines and a complete flush. The light came on when bleeding the first rear but went off after I re-bled the fronts.
I just carried on and bled the rears, topped up turned car on.. all good.. strange one!
