1 - 20 of 21 Posts
Now that I have had vtec at 3700 rpm for a couple of days I have realised that the brakes are a bit on the weak side. I did notice this coming from Rx8 to FN2 but the extra grit as now highlighted it more.
I don't want to go down the lines of a big brake kit due to cost otherwise I'd get Stoptechs.
What are the other options in your opinions. Was thinking of HKS lines with different pads. Is the differences worth it?
aka Colin
I've upgraded lines pads discs and fluid. Huge improvement over stock will give so much more stopping power but nothing like a stop tech kit.
I'd love the Stoptechs just can't afford them ! Just wanted something in between the two.
aka Colin
Well do the pads lines fluid and I'd recommend grooved discs too. Works pretty good for me matey.
Unbelieveable Vteccers
Stoptech do a Powerslot 348mm big disc Disc upgrade for £355 From Abp. It uses stock caliper but spaces them out to fit the larger disc, Add to that feredo 2500 pads and thatshould do the trick. :popcorn:
I was looking to use the stock discs till they had to be replaced. Would I still feel the difference just with pads, lines and fluid?
Oh yes. I've still got OEM discs and my brakes are fantastic compared to stock. Just got DS2500s, Stoptech Lines and RBF600. :cool:
That's more like I had in mind Loxy. Did you do it yourself or get TDI or someone to do it?
I have the 350mm powerslots, EBC reds and standard lines. Breaking is improved a lot although I'd still kinda like to get some new lines too.
If your on a budget you cant beat upgraded pads and the lines are cheap enough (less than £100) For me, my standard discs had warped and I believe its a bit of a common problem so I've got Dixcel Heat Treated Rotors which are excellent.
I have this on mine with goodridge hose and red stuff pads front and rear.
Driving fast is about confidence and this kit, is 100% improvement on stock, and you'll brake a lot later.
Regards
RDG
Cheers guys. Emailed TDI North. Going to get HKS lines, Ferodo DS2500 front and rear plus upgraded fluid. Should do the trick.
Excellent, good choices! :thumbsup:
Discussion Starter #17
Going to do a review when I've had them done but won't be for a few months as my last trip to TDI wiped me out.
Thanks to all for the advice.
Discussion Starter #18
Can anyone with the ds2500 tell me what the dust level is like. Cleaning alloys is a pet hate of mine.
Yeah they are good at that! But it's always worth it!!!
Not good mate! Ive got white wheels which is even worse! The rear greenstuff rears give off far less but are nowhere near as good
1 - 20 of 21 Posts
