Hi guys, I'm in a bit of trouble trying to source this part (No. 9 on diagram) I have tried Lings, Honda and cox's to no avail. If anyone could help it would be most appreciated. Need to get my car back on the road before Sunday.
Edit: the pipe is the furthest right. (didn't realise it wasn't that clear on here)
Any idea if this is the cable?, its the same with engine on and off just wont go in no matter what way you come in from. All other gears are fine.
Thankyou.
Hi all,
I had a visit from Tooth Fairy couple days ago.
My wife took car, car started and later on when she try to start again, starter just spin like crazy.
My guess is, since there is notorious SMF from CG clutch specialist (specialists indeed) inside, that my teeth are gone.
I have 2.2 2008...
Howdy
Started to notice that the Civic only blows warm (engine is up to temp) when I am revving it, when idle it's mostly cold/cool.
I suspect the thermostat is stuck open but hoping to get a 2nd opinion before I start working on it.
Hi guys
New to this forum but wanted to run something by you all ive just changed the timing chain guides etc after an oil pump chain failure on 2007 honda civic 2.2 all back together now starts and ticks over fine but when i even touch the accelerator get plumes of white ish smoke from exhaust...
It never happened before, but in the past few weeks, there has been a grinding sound when I try to switch into second (I press the clutch all the way down, still happens, though rarely, hurts my heart everytime). I let off the clutch and try again and it goes into second.
So I found some...
