1 - 20 of 36 Posts
Just wondering if anyone else has burning oil issues. I've heard honda's burn oil in vtec anyway . If anyone can shed some light would appreciate it a lot
Mines burning 1-2 ltr every 1,000 miles ruffley. I have to top it up every month :s. Does anyone know what it might be
5-30 synthetic Mobil 1 I bought car from Honda dealer in jan so I guess making a phone cal tomorrow
Does it get revved hard etc.
I would perform a full oil change with new filter and a triple ester oil such as Fuchs Titan Pro S, Motul 300v or Millers nanaodrive in a 5 40 viscosity. this is the same thickness cold and slightly thicker hot so prevents burn off at high rpm.
I would drive slowly and allow the engine to warm up gradually for the next month and only give it some beans after a through drive - say 20 mins of mixed driving.
So far this has maybe cost a 100quid but its ruled out the oil etc.
If it is still losing oil then I would investigate if your burning it or losing it.
I assume you have checked visually for leaks etc? any blue smoke?
No smoke and no leaks. And runs sweet as a nut. Just baffled. It's under warranty so I'll get garage to take a look. 49k
Discussion Starter #12
Yeah will do and once check ill update forum feed, just wondered if anyone might know lol but thanks for replys guys
ive mentioned this before mine burns
roughly 250/300ml every 600 miles motorway driving crusing at motorway speeds
Oil change was mobil 5w30, but have been topping up with edge 0w30.
If I Vtec hard I reckon it will burn more.
been like this almost 2 years now
I've done a lot of researching on the K20 over the years. In my opinion, if a car is gently run in it tends to use more oil later in life.
Mine uses a bit of oil. More so when I vtec it.
Just thought it was a typeR thing, just check it weekly and keep it topped up and all will be good.
Yorkshire Jedi
I know this will not solve your issue but I have used Fuchs Titan Pro S for 2 years now and not a drop lost. Valve clearance needed at 25k but no oil.
They'll fob you off and say it's normal iirc Honda say up to1l per 1000 miles.
Bedding in correctly is vital and sadly if not do e correctly is only usually found down the line
I changed to fuchs titan 5w30 and my ctr hasn't used any since it was changed in Jan. I was topping up every fill up with castrol 0w30 before this.
1 - 20 of 36 Posts
