1 - 20 of 27 Posts
Hi Guys,
I'm planning to buy a Hondata flashpro, but have a few questions because I want to instal it myself and I'm not a Computer geek.
- First of all is it difficult to instal, or is it a kind of Pug and Play.
- I've got an HKS RSK and the HKS Catback and want to use the Group N map that is on the flashpro does everything work well then like cruise controll and average Mpg.
- Are there things I should be aware of when I'm installing it.
I hope someone can give me some good and simple answers.:p:p:p
Aye Aye....
Very easy to install, you just need a laptop upload the software then whilst attached to the laptop, plug the FlashPRO into the OBDII port (under the steering wheel) and then upload the map, you would see better gains from your intake and exhaust if you got a custom map but it will all work yes :)
I would say that the AFR is very rich and as such your mpg will fall :(
Hi Guys,
Don't use Group N if you change the intake. It becomes dangerous for the engine with AFR almost 10:1 (too rich) with Group N calibration.
What do you mean with AFR very rich and mpg will fall, I think it is good with a lower mpg.:(
lower mpg is bad surely :p
Grp N is only ok on a bone stock car, once any modification is made it runs very rich and at a ratio of around 10:1 you are rinsing any lubricant off the bores with petrol- what is affectionately known as bore wash and it will damage an engine over time, and probably the CAT a lot sooner
If you contact Vitviper or CivicRSA on here they will be able to Etune your car safely in the meantime for a small fee or properly tune it for a slightly larger one
Stephen
Stephen
Oke, now I understand.:D
Have a read here FlashPro Help
when you have the unit in front of you it'll make more sense, plus it comes with full instructions.
I've read Flashpro Help, just one question.
When I have put in my calibrations like HKS RSK and HKS catback and put in on MAFcalibr., have I then already made a sort of new map and when I load this I have got then the lowered V-tec window max. rev. 8600 rpm.???
I'm not sure what you are asking for. Please precise.
Try to explain what you are asking. We can try to help you.
stock cal is 10.1 @ wot so what's the difference?
anyway groupN sucks and it's only to lower vtec and rev @ 8600.
if you go for the flashpro go for a tune or stay stock!
4th wot datalog with 60mm one exit catback no flashpro.
4th wot datalog with injen cai no flashpro.
4th wot datalog flashpro maf cal-injen cai-rrc-race header-70mm catback.
how much is the hondata flash pro and what are the benefits on a stock ctr fn2
You can purchase a Flashpro from any Hondata dealer
With a 100% stock FN2 you will benefit from:
- No rev hang
- Raised rev limit
- Lowered VTEC point
- Better throttle response
- Better mid range power and torque
- Datalogging - which will teach you a lot about your engine.
the stock cal and the groupN cal are the same in fuel.
Hondata didn't change the fuel. You can compare the two cals on the flashpro manager.
Basically Hondata advanced igntion about 1º and changed the cam angles at wot and vtec point.
- No rev hang
- Raised rev limit
Whats rev hang?
Reactions: ctoddy91
1 - 20 of 27 Posts
