1 - 13 of 13 Posts
Am i doing something wrong, or does this not work?
Basically i have paired my phone to the HFT and imported my phonebook, i can scroll using the nav screen and call someone, have tried the voice dialling, but not having much luck with that bit yet! What im wanting to know is when i recieve an incoming call, is there a way to get it to display the name of the caller instead of the number?
Thanks in advance
I don't think so. I emailed them to ask the question. The only solution is to mount your phone somewhere you can see the screen, or mute the cars ringtone and personalise you phone ringtones for your contacts.
It's a bit disappointing really. :(
phone tranfer to sat nav
Thanks in advance
how did you tranfer to sat nav i got 2006 ex
You can't transfer numbers on pre 09 models as the HFT and Navigation have updated software/hardware.
There is no known way of showing text instead of numbers :(
Yes, what he said. :-(
Ahhh damn it! Seems a bit silly to not hae the names, its like they expect you to remember every number in the phone book and know the name. Theres an option to add number to HFT, so i guess this doesnt allow you to use a name either then? :(
Hi guys
just spotted this thread.
I've got 57 07 EX, but I believe that I can't even see numbers. I just checked my manual to see if I can scroll through numbers but all I can see is voice operated entrance of numbers and to call a number by name. Am I correct?
cheers
Hi guys
cheers
See post 5 above ;)
Post 5 also states "You can't transfer numbers on pre 09 models as the HFT and Navigation have updated software/hardware."
So as your 57 07 EX is a pre 09 model you cannot transfer numbers - didn't think is was that difficult to understand but hay ho!! :facepalm:
If you understood English grammar correctly, you would realise that I wasn't asking how to transfer numbers etc.
Post 5 and 7 should state
'There is no known way of showing text OR numbers :sad:
Hey Ho to you!
I'm sorry but it was my understanding that if you can't transfer numbers on a car built earlier than the 09 models then there would be no numbers to show.
Post 5 and 7 should not state "There is no known way of showing text OR numbers" since if you have a 09 model car or later you can show numbers as you have the ability to transfer them - you cannot currently show text on any MY car.
1 - 13 of 13 Posts
