I have been running this clutch for some time now on my CRV with torque engine outputs estimated between 378 - 410 ft lbs depending on which map I'm running.
I do believe the 6 paddle metalic/ceramic clutch plate on mine was hand built, fitted along with a 325 pressure plate, release bearing and new DMF.
Like Lee I now have a smooth clutch action as it bedded in, it's still not quite up to the original, but it is being asked to take a much higher loading through AWD!
Recommend CG Motorsport to everyone who is wanting to go the stage 2 or custom re-map route.
It works!
Latest info off there site below.......
Heavy Duty Ceramic Paddle
Clutch kit designed for Fast Road /Street use Track Day/Competition.
Ideal for Mapped or Highly Tuned Cars
The Clutch Kit is direct replacement, for the original equipment clutch, no modifications are needed the CG Motorsport clutch kit includes only the highest grade brand new components.
CG Motorsport Clutch Covers features special single diaphragm design to increase clamp load ,with hardened induction diaphragm ,CNC machined casting ,stronger drive straps and rivets ,the pressure plate provides smooth and precise feel with easy pedal effort .
CG Motorsport clutch kits are load tested; lift tested on our purpose built testing machines for quality assurance.
CG Motorsport Ceramic Paddle Drive Plate have a high heat tolerance quick recovery, good co-efficient friction, high heat dissipation and long life
The Drive Plate hub is heat treated and uses hardened retainer rivets for maximum power and durability.
