1 - 9 of 9 Posts
Would it be possible to get a qoute on a set of Camber bolts for a CTS 1.8 2007? Could you also provide me with a copy of your FRS settings via email at [email protected]? Is there a charge for this?
Discussion Starter #2
Bump
Bump
Hi Leon,
Sorry for not replying earlier.
We carry the different bolts in for the 1.8's. These are still £25.00 inc VAT.
I can ship them to you for £6.50 via Royal Mail and i can inlude our FRS settings if you like, no extra charge.
I hope this helps, and apologies again for not replying sooner,
Rich
Thanks Rich,
No probs buddy.
Sounds good. I'll give you lot a call when I'm ready to make a purchase.
Rich,
I will be buying a set of bolts off you towards the end of the month. What else will I need to complete, FRS?
For full 4 wheel FRS you will need the rear shims aswell.
However this is a little more involved than just supplying them like the front bolts.
You would have to go to your nearest alignment centre and get the current geometry printout, email it to me and i will be able to work out which correction shims you would need to alter the camber and toe to the correct specification.
I can then mail these out to you for your alignment centre to install and then finally check the geometry then FRS will be set.
Hopefully this makes sense,
Rich
Thank for the info Rich, and good chatting to you on the phone, VERY Helpful. I’ll give you a call tomorrow to make the purchase.
Thanks Rich,
Payment sent and thanks for your emails.
1 - 9 of 9 Posts
