Ive read that you can swap out the oem speakers with 16.5cm components and just re-use the cable.
would I be able to get 13cm components to fit?
they are rated at 40w rms would they have enough power for decent volume?
I've got a set of caliber competition components up in the loft and id like to use them if possible.
cheers
Gary
Gary
Yes, with the correct adaptors, I beleive these Astra adaptors allow 13cm speakers, so these would be fine.
Not sure of output of standard head unit, speakers will be limited to the power it outputs. Although should be able to acheive some sort of decent volume, obviously more if you got a seperate amplifier.
Hope this helps.
