Hi I have a 1.8 civic 56 plate auto.
When the car goes to change gears it will pause for a sec then like crazy rev past 4000rpm before changing to the next gear. I changed the filter and cleaned the maf sensor and sounds nicer but hasn't made a difference to the hesitation and pause thing. I got no warning lights but when hooked up to the obd it says:
current fault- p0102 powertrain - mass or volume air flow circuit low input
Current fault- p0113 powertrain - intake air temperture circuit high input
If I press my foot on the pedal lightly basically anything under 30mp the car drives fine but as soon as I need to pick up speed quickly its revving and taking a pause before changing gears.
Anyone have any ideas or should I try buying a second had maf sensor.
56 plate 'auto' will be the iShift.
Have a look in the Hobbyist section as there is an iShift expert in there.
