1 - 2 of 2 Posts
I have a civic 2006 sedan 4 doors with 1.8 engine.
Since the day i purchased the car (used) over 4 years ago, i feel a wobble of the car causing vibration to the whole car. I think its starting from the front and it happens on a speed of 25-30km/h at a constant speed, doesn't happen during acceleration or when removing my foot completely from the gas peddle to slow down. I tried many things but none did work for me:
1. Changed the engine 2 years ago( damaged due to water leak) but i thing they used the same fuel injectors
2. Changed tires
3. replaced lcoation of tires
5. changed CV joints
6. I did a steering wheel aligment
7. changed brake pads
8. changed two engine mounts
9. scanned my car using an autel scanner and it only gave an issue with o2 sensors, so i repalced the sensors with used ones and after few days later the check engine turned on and the o2 sensors gave same problem. so i suspect the catalitic converter is the problem or maybe the used sensors are also damaged.
does any one have an idea on how to fix the problem?
Had the tyres re-balanced? You could have lost a wheel weight
Wheel bearing?
Steering rack bushes?
Lower Control Arm bushes?
Wheel nut stud/nut lose or cross threaded or even partially sheared or elongated from misuse or impact tools?
Get under the car with a pry bar and start looking for movement in bushes to give you an idea where the problem might be
1 - 2 of 2 Posts
