yeah thats what i meantIf you sit in it and run it for a while maybe
Not necessarily. I could be wrong but I think that would have the opposite affect on the battery and could drain it quicker.If you sit in it and run it for a while maybe
Hi Starpoint, if it helps I use my car far long distance only so my car sits for a while every so often while I use my bike. I installed a Solar Trickle Charger to keep the battery topped up. Just thought it may be a good suggestion as you can use them as a temporary device as well.How long will the car last before a flat battery, I can not drive the car for a while due to a broken Arm, thx in advance
I could be wrong though
That is bad for your engine since iddling never warms up the oil good enough.you need around 20-30 minutes of running just to restore what you used to start it, is what i was told
+1Hi Starpoint, if it helps I use my car far long distance only so my car sits for a while every so often while I use my bike. I installed a Solar Trickle Charger to keep the battery topped up. Just thought it may be a good suggestion as you can use them as a temporary device as well.
Oxford Solariser Battery Charger
Amazon.co.uk: Oxford Solariser Battery Charger
Goodluck with the recovery hope you can drive again soon!
Peter.
Oh perfect perfect!Not good idea running engine and not driving it, dont bother doing anything until your arm is better and just try it. Mine sat for 3 weeks and started perfectly this morning.
