Hi all,
I have a Civic 2.2 i-CDTi Exclusive leather i-Pilot and i would like to replace original car radio with a new aftermarker radio 2 din.
I am aware that the main display (navigation screen) and bluetooth will stop working, it’s no problem but I'd like to save the secondary display (clock and AC temperature).
I found only this kit "CTKHD01" but it's not suitable for honda with satellite navigation.
Is there a kit for the I-pilot version that enables at least the secondary display?
Thanks in advance
You need to replace the AC/Sat nav display with standard display and it will then work. The flat panel in front of display also needs changing as slightly different shape.
Thank you for reply. Complicated solution :surprise: i thought there was an easier way.
I don't understand why no one has released a control unit for the i-Pilot version on the market.
I-pilot owners are forced to keep the original stereo :frown2:
It's quite a simple process, I did mine the other way around when I retro fitted factory nav on my mk8.
Sent from my Pixel 3 using Tapatalk
