1 - 20 of 24 Posts
Hi All
Just wondering if anyone can help at all?
I have just removed my Parrot which was plugged in to the stereo via a blue autoleads box. plugged the iso leads back into the stereo and now the car won't start? the engine management light is flashing and showing airbag, vsa?
can anyone help?
kind regards
kieron
I guess the first thing I'd do is get the trouble codes then reset them and see if that helps. If it doesn't, then I'd re-connect the parrot and see what happens. At least once you have the trouble codes you'll have an idea where to start looking. Also there are plenty of people on here who will be able to provide advice once you have the codes.
Thanks for the reply deepdown130
how would i get the codes?, I tried plugging the parrot back in but still the same
many thanks
kieron
Thanks, I think that's all above my capabilities TBH, I think I will call out an auto electrician tomorrow to come and look. I'm puzzled who 2 plugs on the parrot which I just unplugged and plugged in the iso can stop the car starting. feeling very stressed and frustrated lol
Check the fuel cutoff? It's a button inside the triangular panel on the end of the dash. Could have been disturbed when the dash came apart.
I have just looked, do you mean the triangle piece you pop off next to the drivers door? I have looked at that part and cant see any form of button?
many thanks
kieron
found it and it is not depressed. It is showing every warning light? tyre deflation, abs, airbag, VSA
Have you tried disconnecting the battery, wait a few minutes and then reconnect? It may have the effect of resetting whatever is causing the error.
Using an OBD scanner is not at all complicated - don't underestimate your abilities?
Discussion Starter #14
I have disconnected the battery and reconnected to no avail, I have looked at every connector I can see and everything is clicked in place. I can normally figure out most problems but this has me bamboozled. I will look at investing in a scanner but I need the car back on the road asap.
I appreciate all of you help
The car is turning over just not firing
Maybe the engine is flooded. Try pressing clutch several times and then trying to start it.
Just a guess but has happened to me in the past.
Bye bye Honda...
Cranking with the throttle depressed can help a flooded petrol engine, but this is a diesel.
Bye bye Honda...
Did you follow the instructions carefully for resetting the fuel cut off?
Does the battery have a full charge? Sometimes the battery can take a hit when you're working on the car, most likely if you were listening to the radio.
Do you have a spare key to try?
Don't leave the key in the ignition whilst disconnecting/reconnecting the battery or jump starting.
Discussion Starter #20
Thanks for all of your input, The auto electrician came today and got it sorted. He said it was odd as the car was in crash mode he reset it and now all is good. Only cost £40 including checking all the connections from parrot removal.
Reactions: musegroove
1 - 20 of 24 Posts
