1 - 10 of 10 Posts
Put the key and everything turns off start button not working.
Think its the immobiliser on key
If the battery of the key died would this happen or am i looking at something else?
Discussion Starter #2
Also has the key got a solderd imobiliser ?
If i needed a new key could just take the small box out then get a key part cut then just put togeather?
try a new battery in the key.
Sounds like the immobiliser, i would try the following.
New battery
Unplug the cars battery for 15 mins then try again see if that works.
Apart from that i dont think soldering the innards onto another board will make a difference.
Thanks, will have to try in the morning now had to go in the misses car.
I wasnt going to solder anything just asking if i got a new key cut can i just transfer the box inside into the new key will it work? as its the same box thats linked to the car
Yes should work, I dont think the key is your problem though because the key is not attached to the innards ( its a separate unit)..
Its only one screw on the back of the key open and have a look its very very basic. :)
Bought a new battery today and that was the cause. F**king sh*t myself when i tried it first few times as i think it wasnt reading the code so the immobiliser was kicking in. Heres a vid
Luckily it started on the end and now working no problem with starting at every turn, will have to re set all my double din now
How do i post a vid cant see it on taptalk?
Shame i cant get the vid up . Really odd it was
1 - 10 of 10 Posts
