1 - 20 of 20 Posts
Just installed xcarlink. But when I press cd/aux nothing happens? I can see ipod is charging and bluetooth is working but the cd/aux doesn't seem to do nothing.
Did you test it before refitting your dash
I had the same problem, I sent mine back for a full refund
Does this mean unit is faulty? Could it be anything else I.e fuse on car. Did you fit another unit
Sent from my GT-I9505 using Tapatalk 2
mmmm bacon
You could try to change the mode by pressing the mode button on the steering
Just re-read you post, mine wouldn't charge, or recognise any device
I ended up buying a offical honda ipod adapter from USA ebay for £45
Fantastic item (but doesn't have Bluetooth or USB ) but work a charm with my iphone5
See mine charges ipod and bluetooth flashes ect. But can't get cd player to switch to aux
Tried changing using mode button. That still doesn't go to aux. everything but. I really don't think it's the xcarlink. But what else could it be
I even switched the wire from y cable other and still does same . its like cd Port damaged but would ipod charge if this was.
Get it out and start again and test before re fitting, ive had a few occasions when mine has stopped working, but i have taken the battery off for 10 mins and when reconnecting it picks it up again
Has yours been similar to mine. I.e ipod charging ect but cd/aux button won't switch to aux? If I disconnect will I need stereo security code?
Yeah only a few occassions, did you disconnect the battery to fit it?
and no no code on the stereo
Might want to remove and reinstall with the battery off mate
Discussion Starter #18
I'm going to just remove battery for 20 min then reattach and see if that solves issue. Hopefully it will
You should really remove the battery before connecting new electrical equipment
Discussion Starter #20 (Edited)
Well disconnected unit and battery, it's still not working. So looks like it might be faulty unit unless it's my oem headunit
1 - 20 of 20 Posts
