Hi all,
Since I purchased the car, the centre console cubby hole door would not open (the storage compartment I front of the gear stick)
The right hand side seems to be loose as though it wants to open but the left hand side is completely stuck.
Has anyone got any ideas
Much appreciated!
Jake
Is there an aftermarket stereo fitted? Some wires stuck behind there maybe.
If I remember correctly, you came remove some of the dash on the side to get a clearer view on what's going on behind it.
Sent from my SM-G973F using Tapatalk
As @kevven suggested I would suspect wires stopping it from opening fully.
When I first fitted my aftermarket headunit I had this issue, annoyingly I didn't think to check until I bolted everything back into place!
If this is the issue it's easily rectified by removing the center console and tucking any hanging wires up or pushing them back, then test fitting and seeing if you can open the cubby again.
There's a removal guide here: [HOW TO] Get into the dash
