1 - 20 of 32 Posts
Discussion thread for the Wiki page Changing brakes. Please use this thread only for discussing what should or should not appear in the Wiki article. If you would like to add a comment, click the Post Reply button.
Hi
Great article
Are the pads you used a lot more expensive than genuine ones.
If so is the extra expense worth it
cheers
This is a great article which I followed successfully to change my front break pads. However do the same instructions apply for the rear pads?
Is the windback tool a left or right handed thread? Thinking of changing my pads but want to be sure I have all the correct tools before starting.
Will a simple G clamp do the job?
You really should remove the pad carriers aswell and clean the surfaces on these aswell as clean up the metal shims that the pads slide into. Will prevent the pads from seizing in the carrier and then binding on.
Not quite, you'll need a caliper wind back tool to push the piston back into the caliper.
Ok, If I get the windback tool. Do I follow the instructions the same but just replace the G-clamp with the windback tool. Or are there any extra steps or precausions I must take?
By-the-way, where can I get the windback tool? Are they standard, do I have to get one that is specific to the civic?
**R-0571**
Lord of JAE.....
I bought a 20 quid one from GSF, havn't used it yet on the backs, but worked a treat on the fronts..... :) I would add the reminder to top up fluid levels to max and to be careful of the hoses. Also mention that you should copper grease the backs of the pads and allow 200 miles before worrying about screeching (mine squealed for approx 165 miles before bedded in with no squeaking).
Tom
Wouldn't they be better off left clean, the grease would attract dust, and in time clog up and the brakes would bind anyway?:worms:
No because you don't need much and is common practice to use it. (My bro is a mechanic with 25 years experience)
Lord of JAE.....
yep, advice is "sparingly" with every thing greasy around brake components...
Anyone not sure can always ask at JAE for tips advice etc :)
1 - 20 of 32 Posts
