Ok so my passenger side brake has gone, I done the easy part got the correct bulb but how the blo*dy hell do I gain access to the rear brake light??
pop the black plastic cover in the channel once boot is open....... that allows access to the fixings
無限 Unlimited
Its fairly easy actually, with the boot open you'll see a plastic piece of trim (hidden when the boot is closed) in the channel which is level with the tail-light. It has no screws so you'll have to carefully pry this cover off, underneath will be a bolt or two, undo these and then the whole light unit will pull out and you can get access to the bulb holders then. Reverse proceedure to install, then Happy days :)
firm but gentle.... plastic cutlery is always good lol
