1 - 2 of 2 Posts
I have Honda Civic 2006, I have connected audio emulator and it worked correctly, but when i turn the key, i get the CHECK SYSTEM light, then the VSA light, then the AIRBAG light come on, and the car wont start, sometimes the car will start eventually, and other times it doesn't start at all? Maybe someone could HELP.
If you have done any recent mods like you said I would convert it back to stock and see if it fixes the issue, if not it's probably down to honda so they can check the ecu for fault codes
1 - 2 of 2 Posts
