Keep getting this message on the dashboard along with the oil can sign. However, oil is fine and so is water tank, anyone know how I might be able to fix this? Or is it a job to take to the local garage?
Have you tried removing the battery for about ten minutes and connecting it back? Ensure this is not done with the key in the ignition please. Good luck
I hit a puddle full force tonight.. Two mins later car went into limp mode.. Engine management light and check system on dash.. Turned car off for five mins back on.. Car not on limp mode but still engine manage light and check system.. Anyone know off or had this issue before?.. And know what might have caused it??
Same problem for me, everytime I drive over a bump there's a screeching plastic sound underneath. Happened when driving down from a multi-storey car park level
So I know this is fairly common and yes I've read the other threads
so I want to ask, I cant for the life of me find a drain hole in the fuel filler area on my 2.2 diesel - is there one for my car please?
This has been for sometime now and it's getting increasingly frustrating I had a leak in the boot where it runs around the boot the rubber part.
It's also on the rear strut tops?? Where are the common problems at because I can't see anything on the net mk8 civic... Also noticed slight water...
Hello,
Recently my passengers side heated Wing mirror has stopped working, although drivers side is fine.
The electric mirrors move fine on both sides, just seems to be the heated element on that 1 side.
Any advice??
hi guys i have an issue with my car the engine is smoking, smells like burning and there is a weird noise im assuming the car is done but id just like some confirmation lol thank you here is a vid of for refderence.
