do you have a subwoofer in the trunk?Nope. No sound and no steering wheel function even connecting that plug.
Anyone with this or similar setup in a Civic 9gen 1.6 i-dtec (maybe the diesel has an external amp)?
I'm freaking out!
nope, the original system is the same as yours.do you have a subwoofer in the trunk?
Describe your whole setup.. does it power on? did you plug in the key1, key 2 and GND wires? i assume you have they joying HU.Thanks for the tip! No wonder I couldn't see it. I'll check that.
Yes, it powers on and runs without glitches, however there is no sound or steering wheel function. Other than that, all's fine.Describe your whole setup.. does it power on? did you plug in the key1, key 2 and GND wires? i assume you have they joying HU.
check the joying Hu wire diagram and look for the negative (- ) wire in the wire harness. tap into that one. usually the color is black but just to make sure check the wire diagramThanks for the tip! No wonder I couldn't see it. I'll check that.
Ok, steering wheel controls are now working! Thanks!check the joying Hu wire diagram and look for the negative (- ) wire in the wire harness. tap into that one. usually the color is black but just to make sure check the wire diagram
Yes, the amp is located in the centre console, just below the AC controls. It's acessible from the footwell.1.So, the amp is located on the right side footwell?
2.Now play with the android launchers.. i have tested a couple of them cause the oem joying launchers are rubbish..i have now the Nova launcher (bought the pro version). Car Launcher (https://play.google.com/store/apps/details?id=com.autolauncher.motorcar&hl=en) was also nice..
3. Play with the equalizer setting and tuneup the sound...(i saw you also have the one with the digital amp integrated)...
4. Did you change the speakers?
Which loom are the speaker wires on the amp and also where is the Bluetooth module. I am going to do this tomorrow. Thanks in advance.Well, the Civic diesel has indeed an amplifier. I had to connect the speaker wires directly to the ISO plug, otherwise I didn't get any sound.
Final result (obd2 info on screen) :grin2:.
The amplifier plug:
The wires:
Sent from my SM-G950F using TapatalkYikes, this looks so much fuss, makes me reconsider upgrading my HU.Probably better speakers will do...
Ooo, what did you do to the imid? I'm guessing that's a static wallpaper?Final result (obd2 info on screen) :grin2:.
Yes, I had the non-touch unit. It's only a wallpaper. :grin2:Ooo, what did you do to the imid? I'm guessing that's a static wallpaper?
I'm also guessing that you had the non - touchscreen headunit, unless you've found A to set the wallpaper with the connect unit?
Hi can somebody please help with blue wire ?Quick question re the antenna lead, where does the blue wire connect to?
The blue wire is supposed to be the antena + power connector (is somehow amplifies the signal) the Chinese Hu should have a specific wire for thisHi can somebody please help with blue wire ?
